Autodesk Fusion 360 proficient
Created by kiran on 8 March, 2018
WANTING GENERATIVE DESIGN SOLUTION
Hi all!
I need someone to process this kind of joint attached through the generative design tool.
They will be produced in aluminium using the casting process and we need to save as much weight as possible.
It will be around 24 in total (12 + 12 mirrored).
The engineer working with me can be directed to provide the parts in the best way in order to make the job easier.
Anyone that could help me with this task?
Best regards,
Flavio
Here is the file again.
