Autodesk Fusion 360 Users
Created by Magnus Budge on 10 May, 2018
Conversion Mesh to Solid using primatic method
Given that Mesh to Solid (STL->STEP) using a prismatic method is paylocked for hobbyists in Fusion, could someone with full version run a conversion for me.
THANK YOU IN ADVANCE!
Likely, no one replied because Fusions ability to convert mesh to solid sucks no matter what method you use. I bought a subscription to get access to this function and unless you have a very basic model t4hat is all square corners it is unlikely parametric conversion will succeed.
