Our 2nd challenge.
Can you make this simple die with four features?
What about 2 features?
Here's a screenshot of a SOLIDWORKS model making the above die with two features:
And yes, all the pips are on the hidden sides:
A split line, nor a material appearance edition is a feature...so here goes...gimme a minute.
Split is a feature. Can you make it work for in only two features though? I've not tried, but I think you'd need several split features to make it work.
You can skip the fillet if you like. But see if you can think of a way to make the model in two features. You've got seven or eight now.
I don't think a texture qualifies as a feature.
I'll make a new model and post a better image to go along with that terrible drawing. Then the features should be easier to identify.
I posted some new images at the top of the page with the feature tree blurred out.
Do tell, if that is not a cut revolved arc, than how are you doing that? Hole wizard somehow? Very curious. Thanks.
Brandon,
You can always check the solution page for each model. But it sort of spoils the fun: https://grabcad.com/groups/cad-puzzles-riddles/discussions/low-feature-count-challenge-2-solution
