CFD and FEA
Created by Ramachandran Seetharaman on 8 June, 2018
You need to log in or sign up before continuing.
Boundary conditions for the refrigerator compartment.
I have 2 cold storage scenarios in which I find it difficult to give the right boundary conditions
1. This is when the air cooler and the fan are in the same housing and I need the air to circulate inside the room. Air enters the evaporator at a certain temperature and exits at a certain speed, volume, and temperature.
2. This option is when I have a separate heat exchanger and a separate fan. The fan blows towards the heat exchanger. The air enters it and changes temperature at the exit and also loses its original pressure.
How do I achieve these results?
