Design and Performance Analysis of a Power Transmitting Two-Wheel Guided System in SolidWorks this is assignment given to me how can i do this anyone suggest me
design a part by referencing any sample drawing using solidoworks/ ansys design modellor
identify the major parameters
reference the parameters inside solidoworks/ ansys design modellor
define the problem/condition for your analysis ( what are the boundary condition which means what forces are applied on which part and what are the surrounding conditions )
verify the problem results by doing the pen copy calculations which can be used further to verify your ansys results
use ansys mechanical to arrange the analysis system which are to be used
apply forces inside ansys mechanical then apply suitable boundary conditions
run the solution
for advanced ansys simulation you can use parameter option inside ansys mechanical , then you can also optimize the model using optimize function of ansys mehcanical
you can also use Matlab and python for reducing the computation time of ansys mehcanical
