Mechanical Engineering
Created by tomas omalley on 14 June, 2018
I have to use 6mm dia dowel pin between two flanges. What shall be the assembly tolerance for the pin for each flanges. Is it required or mandatory to use interference in one flange and clearance fit on the other ? If that is the case what shall be the tolerance grade for the hole on flanges and pin ? If any body knows please let me know.
