Hey guys
I'm looking for design of grinding machine as show in figure.
when sort of candies, snack, biscuit are poured into grinding machine. The desired output would be:
all of candy shell, plastic fall into one bucket; the rest will fall into other bucket
My idea didn't get approval, so please give me another ideas, or have you seen one which operates like this one, please give me a link
thanks guys
You puted any filter below grinder i seen two bucket your idea is nice just used filter and put below on grinder
the problem is not only grinding candy but also snack, biscuit (which have chocolate, milk). so that very difficult to use filter.
tell me about your all product which u poured into grinding machine. then i will suggest you as per your product cause every product shell is not made by plastic there have different material too
my product as show in fig. Like i said, the main problem is we will pour the mixture of candy, snack, biscuits at the same time. and after that separating plastics from those mixture ( we only care about plastics, the rests will be eliminated)
they are 3 main products
i understand your problem now but i have one queastion would you like to tell me what do you do with candy ,snack, biscuits powder?
Maybe you can look at the internet for a food waste shredder, this will gives you some ideas
Hello,
I think you need a centrifuge machine that manages to operate at a temperature that the chocolate is liquid, so that we can separate by weight and centrifuge all the elements.
we only use plastics which extract from products; the rest including candies, snacks and biscuits powders will be disposed
thanks. But we want to dispose the expired product but not harming to environment so we recycle plastics from these products
i think you can use a tunnel of air to isolation plastic using density and force it to direct plastic
maybe you need to add two or three layers above the net. 1st layer is wired to transmit electricity to gain heat which later will eventually melt the plastic so it will stick on the 1st layer where the chocolate or candy still keep flowing down after being shredded. for 2nd layer, install an air hose with low air pressure (maybe around 1 - 3 bar) to blow up - in case if there is escaped plastic - to stick it to the 1st layer.
that's a good idea, but when plastics stick in layer #1, how can you take them out, beside, when plastics stick in layer 1 by the time, that will block the way to materials flowing down to next layers
You can do on thing make one layer use there heater which can melt plastic and palstc will stick on that than use compressed air used on just reduce biscuits and candy Powder mentioned that kind presser in air and collect that powder in direction of air blow and still plastic materal is stick on that then you removed that too by more pressure in air so you can separate this two things by their weight difference
