When designing various circuits there becomes a need to filter out unwanted signals by using coupled magnetic inductance in a styles similar to a transformer, which is called a Common Mode Choke (CMC).
https://en.wikipedia.org/wiki/Choke_(electronics)
Wherein a transformer has a circuit topology that is for current isolation and can be used for voltage magnification. A Common Mode Choke is for voltage isolation and for current magnification and create a high impedance input, like below :
In addition by reversing the direction of the current on the return path (2-3) the transformer becomes a Differential Mode Choke (DMC) which is very useful for creating a low impedance input , but high differential noise mode rejection like below :
CMCs and DMCs are used for power filtering, high speed differential pair signaling, RF filters, and can be used for low frequency bidirectional couplers.
Some applications are listed here :
https://www.coilcraft.com/en-us/edu/series/a-guide-to-understanding-common-mode-chokes/
and a small video is shown here :
https://product.tdk.com/en/contact/faq/emc-components-0032.html
One other interesting concept is the DMCs can be used to reduce timing skew from cable effects :
https://article.murata.com/en-sg/article/basics-of-noise-countermeasures-lesson-13
However care must be taken into consideration in choosing a CMC or DMC as a low quality one can create more problems than they solve :
https://interferencetechnology.com/be-careful-with-low-cost-quality-common-mode-chokes/
This is a low or poor quality CMC :
and this is a high quality CMC :
