Ansys transient structural analysis in my laptop
When i do transient structural analysis in my laptop it shows me the message which i have mentioned in the attachment .can anyone help me.
Accepted answer
I think if you look at the first error message "Element 1324..." with it likely ending in "has become highly " .. displaced? you may recognize this as being under constrained. I would guess that what you are encountering is that the solution fails because the entire body is moving (so more like a rigid body analysis rather than structural). Make sure your setup is good, that there is some constraint that prevents the entire part from rotation around xyz and translation in xyz (though not necessarily all at one location). Start simple, gradually make it more complicated... can you run a static analysis before a transient? As I don't see the setup, my first focus would be on making sure that one surface is completely fixed (Rxyz, Txyz =0) and then gradually work from there until something breaks -or you reach the goal.
Does that help/resolve something?
