Assembly drawing
I am trying to cut a simple 4 block(in pattern) with a hole from a stock material. I want to cut one block then another block. But in cam works it drill the hole of all the blocks then cut the block. I want to run block by block cutting arrangement
2 Answer
Check Kolkata Fatafat Result Today LIVE with Ghosh Babu Tips, 8 Baji Updates, 220 Patti Chart, and Lucky Numbers.
Kolkata Fatafat (Kolkata FF) has become a popular choice among many players in India. Kolkata FF is a game that is adored in India because it combines speed with excitement and regular results.
