can create gear. help Straight Bevel Gear
![Bob Wiley](https://d2t1xqejof9utc.cloudfront.net/members/avatars/5793835/feed.jpg?1585773324)
The apex of all pitch cones must intersect at the same point. There is no way to have 2 bevel gears on parallel shafts that are not collinear mesh with a common third bevel gear like you have. I’ve attached a screenshot that shows just two gears but all straight bevel gears that mesh together must have only one single common apex point.
Because the two shafts are offset and parallel, there is no point where a common intersection of the pitch cones can be achieved. There is no solution to your problem using 3 bevel gears.
Either the shafts must be moved to be collinear or additional intermediate shafting and gearing must be added.
