can i use multi properties on single part in catia.? Ajay Agrawal 2 Nov, 2012 02:11 PM means if i am using part modeling and create circle then square so can i put glass property on circle and steel on square or i have only choice to use assembly. 2 Answer G15 Answered on 2 Nov, 2012 08:18 PM Depends on the workbench: PDG every Body can have its own material GSD unlimited materials. Material for geometrical Set, also for surfaces. Greetings G15 Answered on 3 Nov, 2012 04:59 PM hope this file will help Part1.CATPart
