Does any one know how to convert STL file to solid file through Reverse engineering in Unigraphics NX and CATIA ? ? Hariprakash P 2 Jul, 2018 03:54 PM About creating solid file from STL format. 2 Answers Hegedűs György Answered on 2 Jul, 2018 10:00 PM If you import the STL file in NX, you can set an option to convergent modeling. In this case your STL file will work as a solid model. Or you can use the Reverse Engineering modul to create your features for modeling. Hope this helps! STL Import NX.png dhananjay rehere Answered on 3 Jul, 2018 03:41 AM https://www.youtube.com/watch?v=JS6F47fVFpE
