How can i change the 2D FEA calculation units in autocad mechanical i.e. lbf to N, psi to N/mm^2 ?
While applying the force in 2D Fea analysis in Autocad Mechanical, i haven't find any way to change the force unit from lbf to N?
What will be the process for the same?
The units are taken from the template.
So you have to use the command "New" and choose a template with the desired units (e. g. AM_iso.dwt).
AFAIK that's the only way (Version 2018)
