How can I change the entire componets from .iam to .ipt once finished the assembly?
The thing is that I need to load an entire assembly and part of its comonents must be defined as a fixture from CAD to be read as a fixture using a CAM software (EDGE CAM)
Here is a tutorial I done for someone else and another question but it is just the same steps only you do not want to scale it just save it as IPT.
Opss sorry I forgot to add like to the tut...
http://grabcad.com/questions/how-do-i-scale-a-model-in-inventor
