how can i select the plan.1 cause it is unable to be selected ;
Hi everyone !! i had an issue in Catia , how can i select the plan as it is indicated in the tutorial video in 04:16
**tutorial video link : https://www.youtube.com/watch?v=ffV9tz2y7xw
and take a look on the issue that i had on the photo capture ( i can't select the plan.1 ) " see the attachment"
what shall i do to avoid this issue ?
Accepted answer
(I think you meant "plane.1" ?)
This issue is probably due to you're using Hybrid Design, while the tutorial is not.
So, stop what you're doing and close this CATIA file. Start a new CATPart file, but this time make make sure you do NOT choose the Enable Hybrid Design option. Now, go back and follow the video from the beginning. (The cylinders and plane should be contained in a Geometric Set - not the PartBody)
