How can I use models in the Grabcad community ?
I see a lot of 3D model and I just want to work it by myself. However , I get trouble with dimensions, I do not know what exactly dimensions for each part. So please help me. I am a solidworks beginner. Thank you very much.
Try using the measure command in Solidworks. You can measure between points on the model and see if they are what you are expecting. Be careful doing this because some of the models on GrabCAD are for looks only and may not represent the actual part.
if you find solidworks very hard and confusing, try fusion 360 since there are many more youtube videos on how to use it and it is designed for better workflow.
Hey Nguyen,
I think you are going to struggle to get any useful answers to this question. You need to specify what you are trying to make or model and be more specific in the help you require. Solidworks is very easy when you have learned the basics to it and the best way to learn how to make a decent assembly is often to pick something up from your desk or office and draw it up part by part taking care to measure each part carefully. There are a lot of useful YouTube videos available to help people with little to no experience in solidworks, but as previously stated you may struggle to find help unless you narrow down what you are asking.
