How can we change the direction of gravity, while modeling in NX 8.0 ?
I am having problem with the direction of gravity in simulating a model with mechatronics concept designer.
Hello Nitin,
by default the gravity in Mechatronics Concept Designer is set to -9806.65 mm/s² along the Gz direction.
However, you can change the Gravity to any value and any direction along the Gx, Gy and Gz vectors.
You can do this in the preferences or the customer defaults for the Mechatronics Concept Designer.
(Menu bar: Preferences -> Mechatronics Concept Designer).
Best regards
Viktor
