how do i hide all planes,constraints in assembly in CATIA ?
in assembly i have some thousand parts, am not able to hide all planes,sketches,constraints etc. how should i proceed. i tried with search tool but its not useful ..
9 Answer
or u can use view options, using customize view parameters. like picture.
Necmi
Answered with a tutorial: https://grabcad.com/tutorials/how-do-i-hide-all-planes-constraints-in-assembly-in-catia
you must search them by their names or types. Go: Edit-->Search (or Ctrl+F). search menu will pop up. if you want to search in assembly, select workbench as assembly design. if you write name as "*plane" and click "Search and Select" (binoculars with yellow arrow) and then push Hide/Show, all the origin planes will be hidden. if you write name as "plane*" and make same selection this time the planes which you created will be hidden. you can also use type for selection of constraint etc...
On menu line select EDIT, than on pop-up menu select SEARCH, than go to the tab ADVANCED. On this tab you choose the right parameters: i.e. planes and axis. Selection of more than one parameter must be done with boolean operator "OR". When the parameters are set, then you click SEARCH and after that you click SELECT. Now all desired features are selected and painted in orange (in assembly and in structure tree). Click HIDE command (pop-up menu "view" or icon on toolbar "view") and that's it.
Answered with a tutorial: https://grabcad.com/tutorials/how-do-i-hide-all-planes-constraints-in-assembly-in-catia--1
before saving the parts created under part design hide all planes and sketches
so in that way if you bring in the models under assembly you don't see it.in case if your part itself contains so many planes and sketches go to tools under drop down select hide all planes,all sketches etc...and you can do the opposite(i.e show all planes sketches etc...)
In the bottom right of your screen there should be a white text box. Type t:plane and hit enter. This will select every plane in your model tree. From there you can simply use the Hide/Show command. You can use this to select other features as well.
I need help with a similar problem. I'm learning CATIA and want to sketch and do som 3D modelling. What I'm searching for is the X-Y-Z plane "star" in the middle where I can chose the sketch plane. Where can I find it? Here is how it looks like right now
Answered with a tutorial: https://grabcad.com/tutorials/how-do-i-hide-all-planes-constraints-in-assembly-in-catia--2
