¿How I can open a STP or STL file in Autocad 2008?
Open 3D standard files in Autocad 2008
there is no direct method for opening STP or STL... therefore i uses an alternate method using solidworks...
my steps for opening is :-
1) open the file first in Solidworks...
2) after that save it as ACIS (SAT) file type with version 1.6
3) then open autocad (mine is 2011)... and use import under file menu...
4) set file type to ACIS (SAT) and then open the saved file in step 2
