how to add explode view of assembly in draftingin catiav5
when i was create an assembly but i want to place explode view of assembly in drafting
You must create scene. first click scene command. write the scene name or auotmatically named. click OK. use Compass and explode assembly. then exit scene (button like exit sketch). after these in drafting click isometric view, and go assembly tree. first select the scene which you create then click the model. it will pass automatically to drafting.
