How to change the dtl to iso dtl standards and creating drawings?
i am using proe 5.
put a line in your config.pro file
format_setup_file C:\Program Files\proeWildfire 4.0\text\iso.dtl
if that doesn't work try replacing format_setup_file with drawing_setup_files
all config options can be found here:
http://www.cad-resources.com/WF5_config_options.pdf
thank you friend
