How to convert .SLDPRT files to .STEP files ?
How can we convert solidworks files to .STEP files, which is a common file format can be opened in many software versions.
Convert with DATAKIT CrossManager
This is another problem we encounter in using SolidWorks software package.
Answered with a tutorial: https://grabcad.com/tutorials/how-to-convert-sldprt-files-to-step-files
iges and step are most common. there is lot of information loss in these two format. whereas parasolid file retains most of the information.
If you want to learn more about SW please visit my website http://adf.ly/1KJoDB or http://adf.ly/1KJpR0 & you will find my Email there, All your quiries i'll do my best to answer them :) & if you need more help then we can discuss & i'll help via skype :)
Use GrabCAD Workbench. Upload you sldprt file to workbench then you can right click on the uploaded file and select "download as". You can download the file in the format of STEP, IGES, STL, Parasolid, ACIS, JT, or VRML.
If your still struggling I'd advise you to check out my tutorial for converting files in Workbench
How to convert CAD files in Workbench
Your procedure is correct, I did what you explained and everything was fine. I think you may have a problem with your software
The common file format that can be opened in many software versions is iges.
