How to do the chain component pattern
I was trying to do a chain component pattern, but (all segments of the profile must be tangential and they should be of one contour only) when i pick the sketch
Accepted answer
Go to :
Tools -> Spline tools -> Ajust spline. Then you will have to select every section of the sketch
Your problem should be fixed this way ;)
0 Other answer
