how to export points in catia into .txt file or to excel sheet?
I got this from some user in some forum. Did some modification in it as well. You may try to find out if its working.
Dim objGEXCELapp As Object
Dim objGEXCELwkBks As Object
Dim objGEXCELwkBk As Object
Dim objGEXCELwkShs As Object
Dim objGEXCELSh As Object
Dim fs, f, f1, fc, s
Dim coords(2) As Integer
Dim PartDocument1
Sub CATMain()
CATIA.ActiveDocument.Selection.Search "CATGmoSearch.Point,all"
StartEXCEL
ExportPoint
'objGEXCELSh.Application.ActiveWorkbook.SaveAs (ExcelFolder & Left(CATIA.ActiveDocument.Name,Len(CATIA.ActiveDocument.Name)-8) & ".xls")
'objGEXCELSh.Application.ActiveWorkbook.Close
End Sub
Sub StartEXCEL()
Err.Clear
On Error Resume Next
Set objGEXCELapp = GetObject (,"EXCEL.Application")
If Err.Number <> 0 Then
Err.Clear
Set objGEXCELapp = CreateObject ("EXCEL.Application")
End If
objGEXCELapp.Application.Visible = TRUE
Set objGEXCELwkBks = objGEXCELapp.Application.WorkBooks
Set objGEXCELwkBk = objGEXCELwkBks.Add
Set objGEXCELwkShs = objGEXCELwkBk.Worksheets(1)
Set objGEXCELSh = objGEXCELwkBk.Sheets (1)
objGEXCELSh.Cells (1,"A") = "Name"
objGEXCELSh.Cells (1,"B") = "X"
objGEXCELSh.Cells (1,"C") = "Y"
objGEXCELSh.Cells (1,"D") = "Z"
End Sub
Sub ExportPoint()
For i = 1 To CATIA.ActiveDocument.Selection.Count
Set selection = CATIA.ActiveDocument.Selection
Set element = selection.Item(i)
Set point = element.value
'Write PointData to Excel Sheet
point.GetCoordinates(coords)
objGEXCELSh.Cells (i+1,"A") = point.name
objGEXCELSh.Cells (i+1,"B") = coords(0)
objGEXCELSh.Cells (i+1,"C") = coords(1)
objGEXCELSh.Cells (i+1,"D") = coords(2)
Next
End Sub
I've tried your Macro and it's looking promising- it opens excel and sets up titles, plus it highlights the points in catia- but the code gives an error in this line-
Point.GetCoordinates (coords)
and to be honest, I've no idea what I'm doing when it comes to VB.
If it makes a difference, I'm using windows 8, and Catia R18.
any ideas?
Thanks, Simon
Edit- I also get an error message-
"run-time error 13
type mismatch"
