how to make chain assembly in catia
how to fit chain along curve
3 Answer
there is no quick way that i know to do this, when i have had to do this task i use a master part with the center curve for the chain and then use points along this curve to set the center points of the pins. Unfortunately from there it is a lot of assembly constraining, If you do find a more elegant method i would be very interested
thanks C Malia
Hi friend, try to check the link before, I sent you, whatever comments, or suggestions the are welcome.
Have a good day,
Best Regards,
Another comment, is you can look for some information, in youtube. there are so many tutorials, about how to assembly a chain in catia.
