How to render IGES files using 3DSMax?
HI, When I tried to render a file using 3dmax everything rendered EXCEPT the part that was the integration of your IGES file. Do you understand why?
3 Answer
Once I had designed a club model on catiaV5 and then converted it for 3dMAX iges. So only the converted surfaces was rendered without metarial the first time and you have to add metarial class for each part rendered well expet the part integration.
This is a really good site for
3D's max and other Auto desk software
I don't know if it will help but it is well
worth a visit as there is many great
tutorials on there also @
http://area.autodesk.com/
