Is there a way to create a watermark in an Inventor Drawing?
I have looked it up and I can't find a way to create a watermark for the drawing. I would like to do this for my drawings for the company I work for and wasn't sure if I could do that within inventor or if I just need to apply it to the pdf saved from it in adobe.
Accepted answer
As far as I have read there is no actual watermark feature for Inventor. A work around would be to create an image with a high level of opacity in photoshop. Right click the title block area, edit definition, insert image, and SEND BACKWARD to go behind any block info. Save changes and back at the paper space this will put the image behind your drawing dimensions. Not sure if this is what you were looking for, but it's what I use to put our logo behind drawings and makes it harder to just screen capture drawings.
