Not Parallel Surface with Swept Cut
When I Use Swept Cut to make this part as drawing attached I get not parallel surface
How I Can Fix it Please
2 Answer
Check "Profile twist"
Your section is not prependicular to the swept cut so it wouldn't appear like triangle or parallel surfaces.
