Guys I have an assembly in CREO 3.0 which i have exploded by edit position command, then I saved it. Then I have created a new drawing file and tried to insert the exploded view but the view which I is displayed in the drawing is not the one which have created by edit position command. Kindly help.
You should mention the CAD program being used.
In SOLIDWORKS, you'd need to right click on the drawing view, choose properties, and specify that you want to show the exploded configuration.
Other programs likely have a similar mechanism.
