Remove part from part
Hi all, I am trying to remove a part from a part, while keeping the part to be removed, or to get a similar result.
I have two parts. The one to be removed(a cutting blade) that needs to remain untouched. The second part, on the other hand, is a plastic piece. Basically, the blade goes into the plastic part, so in the latter I need a recess of the same geometry as the blade. Of course I would like to keep a connection to the original blade part so that if I make changes on that one they are also reflected in the cutout. I can copy the blade body to the plastic part so I can use the Boolean removal function, but then I don't know how to accurately position the blade body relative to the body of the plastic one.
Any pointers on how to proceed? Thanks
1. Like you said, copy the blade body to the plastic part. Hopefully you pasted with a link.
2. In the Part Design workbench, there is a constraint tool (very similar to the constraint tools is Assembly Design). Use constraints to position the blade body relative to the Part Body of the blade.
3. Now do the Boolean Remove.
