Snap Point Problem in NX 10
Hi, i have a problem with some of the snap point tools when i creating curves in NX10. For example when i hover over with my mouse on a curve after finishİng the sketch, the mouse could not catch the midpoint snap tool on that curve even it is selected on snap point segment like in attachment. I need your help.
Thank you all.
2 Answer
Hello Ugur,
same problem here in NX10 (version 10.0.3.5), I think this is a bug. If you use an active command, NX recognises the snap points (for example the midpoint). I've just checked it in NX11 and it works fine.
Try to upgrade your version.
Hope this helps!
It works in NX 11 version update and use... It's good in 11
