Solid Edge Frame tutorial
This tutorial presents step by step actions to create 3D frame. From 3D frame model 2D drawing will be created with part list and dimensions.
5 Answer
Frame with dimensions to build.
Answered with a tutorial: https://grabcad.com/tutorials/solid-edge-frame-tutorial
Very nice, still I prefer SW 3d sketching abillity. Saves more time then opening a new plane every time.
Also it's important to mension that when marking the lines in the frame command for an intersection of 3 or more lines, one have to pick 2 lines every time in order to control the end conditions of the frame properly.
Thx.
Thank you for this very useful tutorial.
Step 13. should have as nr 1. select "include" and then wireframe chain, as a beginner it was little confusing. But later on it was mentioned tbh...
Thanks for the nice tutorial!
No problm, SE supports 3D sketch also.
