Solidworks Weldments Weld Bead feature's radius problem
Please help me understanding the dimension of weld fillet that we give in Solidworks Weldments using Weld Bead feature. I have attached a screenshot containing some dimensions, those marked ones should be nearly same ( or at least one nearly half of other, if one is radius while other diameter). Why is this problem happening? (all dimensions are in mm)
