Toggle clamp how to trace the handle path to create an opening?
Hello, how should I process to find out the handle path in this particular case with multiple joins?
Thanks
Accepted answer
The path is generally close to an arc. While not exactly an arc, for purposes of clearance an arc could be used.
Create a sketch with components for each of the handle pieces at the beginning position. Create a similar sketch with the handle pieces at an intermediate location. Create a third sketch with the pieces at their final location. Create a fourth sketch for the arc (or arcs) that connects each of the 3 original sketches.
