Tools are disabling while switching from assembly to sketch and sketch to assembly? Bhavanasi L V Nagababu 4 Jul, 2015 02:37 PM Initially I uploaded parts to assembly, now I switched part to sketch for editing. After this I again switched to assembly. Now the problem is The constraint tool box and manipulation tool box get disabled whats the reason? Capture1.PNG 1 Answer özgür kesebir Answered on 4 Jul, 2015 06:28 PM Because you have to activate assembly design. If you check your blue named level in picture, you will see it. Double click top assembly will activate assembly easly.
