Tutorial 55: How to use circular pattern command in Solidwokrs
2 Answer
Please check my tutorial in tutorial45 website
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-55-how-to-use-circular-pattern-command-in-solidwokrs
From the Sketch command manager, click on the down arrow of the linear sketch pattern tool. Then you can see the “Circular sketch pattern” tool and click on to select it.
Hope this will work.
