Tutorial - Stress Analysis in ALGOR?
Tutorial on Stress Analysis in ALGOR. The model used Support Bracket by Manolis Theofilos.
Here is the tutorial. Since the model used is created in AutoDesk inventor we will not have any problem using it in ALGOR.
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-stress-analysis-in-algor
Here I am going to show how to apply pressure to a surface. we are going to use the same model.
Answered with a tutorial: https://grabcad.com/tutorials/tutorial-stress-analysis-in-algor--1
Very nice tutorial. I have been playing with ALGOR some time now.
The reason why welds are not defined automatically is because they are recognized as features and not as extra material. You can choose to exclude them from simulation.
Also for a more acurate result the contact type between the backplate and the two vertical supports should be set to sliding-separation, because the parts are hold together only by the welds.
