we want to fabricate small model of archimedes turbine for testing
You'll need to calculate the required dimensions, since only you know the size of turbine that you plan to create.
See the attached image though, the structure appears to be based on proportion, and not on dimensions. The design follows that of a Nautilus shell, or the "golden ratio" of ~1.618
