What is rim diameter of standart Tofaş rim dimensions?
I am looking for rim dimensions for standard Tofaş. Actually I wanna learn:
- Rim Width
- Bolt Pattern (especially this one)
- Offset
- Center Bore
- Rim Diameter
Can you help me?
For standard Tofaş rims, the typical dimensions are a rim diameter of 13 inches, a rim width of 5.5 inches, and a bolt pattern of 4x98 mm. The offset is generally around +30 mm, and the https://fluxnet.com.au/ center bore measures 58.1 mm. These specifications are commonly found in many standard Tofaş models from the 1980s and 1990s. For precise details, especially for different models or years, checking the vehicle's manual or consulting a specialist is recommended.
