When saving an Inventor drawing as a DXF file how do I only show my sheet metal flat pattern not the isometric views etc Ben Elliott 7 Mar, 2019 02:19 AM When exporting to a AUTOCAD 2000; 1:1 Model space is there any way I can only make sure that my flat pattern will be exported as it will be laser cut and I don't need to show any base views. 1 Answer CadCloud Answered on 7 Mar, 2019 06:28 AM Flatten the item and then use "Export as " dxf. export.png
