Altium Designer Tutorial 39: PCB Layout 10 design rules.
Altium PCB Layout 10 Design Rules
In this video i added my 10 previous video of Altium designer pcb layout rules.
1) Clearance between Not plated through hole and copper.
2) Clearance between SMD or THT connector and PCB Boardcontur.
3) Merging same nets in Polygon.
4) Clearance between copper/Polygon and PCB Board contour.
5) Clearance between Fiducial marker and keepout & Fiducial marker and all (component/copper/TH etc).
6) Polygon clear under SMD components pad.
7) Via No Net (detecting via's which doesn't have any net name).
8) Via under SMD component ( detecting via's which are placed by mistake under SMD pads).
9) Clearance constraints between Test point & THT(2mm)/SMD(2mm)/Test points(2.54mm)/ All components(0.5mm).
10) Schematic Width Constraint.
#Altium designer PCB Layout rules
#Altium query
#PCB Layout rules
