Ansys Tutorial - CFD Of Venturi 2D Using Fluid Flow (Fluent) Module
In this tutorial I have made a 2D shape of a venturi using the same software.
You will see the changes in the velocity and pressure at the throat region of the venturi , as the fluid reaches the throat region the pressure drops and the velocity increases.
