ANY ONE TELL ME ABOUT DRAWING IN CREO
"ANY ONE TELL ME ABOUT DRAWING IN CREO."
First of all go to File>Prepare>Drawing Properties
In the drawing properties tab click on change in front of detail options
In the options ensure that witness_line_intersection value is set to yes
Now in the drawing click on dimension and in the attach type tab select intersect
Select both the fillet edges by pressing ctrl
And also the other two fillet edges again with ctrl pressed
Now press the middle mouse button to place the dimension and select vertical from dim orient tab
You will have your dimension
