Autocad Practice Exercise 11 | Autocad Isometric Drawing | Changing Plane in Autocad 3d | CADable
Hi friends welcome back to CADable. This is Engr. Ibrahim Omer. Here's a brief overview of the features and commands you'll be learning in this AutoCAD practice exercise:
1) AutoCAD Basic Settings: You'll likely start with some basic settings in AutoCAD to set up your drawing environment.
2) AutoCAD 2D commands: Understanding 2D drawing commands is essential before moving on to 3D.
3) Press Pull: This is a command used in AutoCAD to extrude 2D shapes into 3D objects.
4) Visual Settings: Adjusting visual settings can help you view and work with your 3D models effectively.
5) Changing Plane in AutoCAD 3D: Learning how to switch between different planes in a 3D workspace is crucial for creating complex 3D objects.
6) 3D Move: This command allows you to move 3D objects in your drawing.
7) Solid Union: Solid Union is a command used for combining two or more 3D objects into a single, unified object.
It is a good exercise for beginners and it will be a good practice for beginners.
Kindly use play pause technique for practice. Feel free to ask your queries in comment section. I will try to answer each and every question.
Keep practicing as practice makes a man perfect.
Follow our Channel:
https://www.youtube.com/c/CADable
Chapters of the tutorial:
Introduction 0:00
AutoCAD basic setting 0:29
Making base of the part 1:10
Making a rib 4:18
Combining bodies 6:45
Making a keyway 7:06
Conclusion 9:20
#autocadisometricdrawing #autocadpresspullcommand #autocadpracticeexercise11 #CADable #autocadpracticeexercises #cadabletutorials
