CATIA V5 - Graphic properties colors compared to materials
In CATIA V5, graphic properties colors and materials are both used to control the visual appearance of a model. However, they have different purposes and effects.
* *Graphic properties colors** are used to control the color of the lines, surfaces, and other graphical elements of a model. They can be applied to individual features or to the entire model.
* *Materials** are used to control the appearance of the surfaces of a model, including their color, shininess, and transparency. They can be applied to individual features or to the entire model.
Step 1: Case study using the Panton Chair
The 3D model can be found at:
https://grabcad.com/library/panton-chair-82
In general, graphic properties colors are used to provide a quick and easy way to change the appearance of a model, while materials are used to provide a more realistic and detailed appearance.
Here are some examples of how graphic properties colors and materials can be used in CATIA V5:
- You can use graphic properties colors to change the color of the lines in a drawing. For example, you could change the color of the hidden lines to red so that they are easier to see.
- You can use materials to change the appearance of the surfaces of a 3D model. For example, you could apply a metal material to a car model to make it look more realistic.
Ultimately, the best way to choose between graphic properties colors and materials is to consider the specific needs of your project. If you need to quickly change the appearance of a model, then graphic properties colors are a good option. If you need to create a more realistic and detailed appearance, then materials are a better choice.
Keep in mind that graphic properties appearances will transfer as STEP files towards other software solutions.
