CATIA V5 - STL to Part Design
There are multiple reasons why you would want to convert an STL file to a Part Design model. This tutorial will show you the workflow.
3D model used in video available at:
https://www.thingiverse.com/thing:4142652
  1. Step 1: Convert STL (Mesh) to CAD(Part Design)
    The first step would be to acquire a STL file so you can work with it. I have made the following tutorial using an STL available online at:
    The workflow will make use of multiple workbenches such as: Digitized Shape Editor, Quick Surface Reconstruction as well as Generative Shape Design and Part Design.
    Video section
    Introduction 00:00
    Digitized Shape Editor 00:50
    Automatic Surface 02:30
    CATIA Model 05:30
    Join surfaces 08:00
    Closed surface 09:30
    Adding planes 12:00
    Conclusions 14:20
    Outro 14:40
