Design of Radial Engine With CATIA
Radial motor design is designed as mentioned below.
We open Catia and enter the part desing menu first.
And from here we enter the sketch at xy from the product tree. Then we make the skeleton drawings that we are seeing below in the direction of the given meter.
  We record every track we make under a specific file.
    shaft
    Main rod
    piston
    Top Bush Button And Alt Bush Bush Button ,Piston Plug Pin ,Piston Pin, Connecting Pin, Main Lever Bearing, Connecting Pin
  5. Step 5:
    After we have made the necessary pieces on the Part design menu, we're done here.
    We will do it in Sarad, we invite them to the product part, ie the product menu, and here we combine the parts as follows.
  6. Step 6:
    Creating and Linking Parts; Piston , Piston Ring , Connecting 4 Piston Rings to Piston
  7. Step 7:
    Top and Bottom Bushing Rods
    Articulation Shaft
    Combination of Upper and Lower Bushing Rods and Joint Shaft
  8. Step 8:
    Piston pin and piston plug pin
    Piston and Articulated Milinin Merger
  9. Step 9:
    Main Rod Rod
    Main Arm Bed
    Connecting Piston with Main Rod
  10. Step 10:
    As a result, we make the radial motor this way.
