Designing a Reduction Spur Gear Box Made Easy: Step-by-Step Tutorial | design with ajay |
A reduction spur gearbox is a type of gearbox that uses spur gears to reduce the speed and increase the torque of a rotating power source. Spur gears are gears with straight teeth that are cut parallel to the gear axis. They are the simplest and most common type of gear and are used in a wide variety of applications.
Step 1: Designing a Reduction Spur Gear Box Made Easy: Step-by-Step Tutorial | design with ajay |
