Electrical Output ports controlled by switch.
In this tutorial, you will learn how to draw an electrical switch port in AutoCAD electrical.
Step 1: Insert Components
1st: Input Connector from "Insert Connector"
2nd: Insert "Power Supply (power source 1 phase)" from the Icon menu
3rd: Place a "Limit Switch, No" from the Icon menu
Step 2: Final Connection
Connect all the components with each other by wire.
